Adjusting camber and caster on wheels
Fien
180
Chester
I've just had a 4 wheel alignment done on my car and the camber and caster results are quite a bit outside the recommended ranges. It was done at Demon Tweeks in wrexham so im confident that they have done a decent job and adjusted it as much as they can.
i'd like to know how you'd be able to fix it or even who would be able to do this? :confused:
the guy said that it had the appearance of being lowered in the past. ive only had the car for 5 months and pretty certain the the current suspension is standard. does anyone know any more about this?
cheers :)
Ronin225
4,647
22
Worcester
Caster angle is how far forward the wheels sit, shouldn't make difference as long as they are the same
Camber shouldn't be more than 1 degree negative per wheel unless making a pure track car as it will wear tyres lots faster
Fien
180
Chester
caster is pretty equal. unfortunately i'm not planning to make a pure track car so would be best to get it corrected, if possible!
