Aftermarket Ateca Boot Mat/Tray
Loadmaster748
Roll on summer.....
Aug 2, 2019
315
130
Surrey, UK
Can anyone recommend a good non OEM source for an Ateca boot mat please? Loads about I know, but wondered if anyone here can point me in the direction of a tried and tested one.
Tell
I pass on the non OEM one but I do have a very good Seat reversible one which is carpet one side, rubber on the other. The rubber side things stick to it so you get no movement of things sliding around in the boot which I was pestered with. The chiller box would bash onto the rear light cover which would drop off in the road as the tailgate lifted. Happended about three times. The mat silicone rubber side up, everything is pretty stuck to it. It is expensive but treated the car since I got fed up clipping the rear light cover back on and hearing the chiller box slide about in the boot. Horton's sell those if you cant get to a main dealer to pick one up.
Seat Part Number: 575061201A
Think it fits all Ateca's apart from the 4x4 with variable boot height. Mines standard 4x4 with spare.
Only accessory I bought for it :). Not into sticky bits for the dash etc.
hamst
93
16
Hi,
Im considering buying the same mat. Do you have a pic of this? There are 2 one semi rigid and one mousse. Also is my boot floor is not adjustable and i have a spare tire under, will this fit?
Or rather
575061201D
Or
575061201B
Tell
Its not 575061201D as per the Amazon picture.
Its not 575061201B as per the picture either.
Its 575061201A.
This one on the Horton site
Its a standard Seat accessory part. It fits standard 4Drive and non 4Drive but won't fit variable floor 4Drive. Text from their site. Doesn't say "Ateca" in big letter on it as per the other two.
This is it in the Seat catalogue.
I have fitted silicone / rubber side up which is for non slip. Doesn't block the side storage compartments either side. Does the job that I wanted which is the chiller box doesn't shift in the back. Anything put in the boot doesn't slide around with the non slip side up. Fits all of the standard configurations but not variable boot as per the Horton text, Seat catalogue gives build codes for the boot... Pass on them. Would go in your boot.
The selling point anchors down things in the boot so they don't move. The other mats seem more designer with Ateca on them :). I was plagued with the chiller box hitting the reversing light access cover on the tailgate and the cover dropping off on the road when lifted... happended a number times. It stopped that since it doesn't move now including shopping.
Pictures... excuse the dirt. The difference between a mat and a tray. Doesn't get in the way of the side storage areas. Non slip silicone side up. The other side plus the dimple side in closeup. Looks boring but does the job well.
That's one of those velcrose storage bags at the back I use for added storage in the boot. 4drive boot.
