air bag light
gethinwr93
145
i was removing the cupholder where the gear stick is and had the ignition on -.- so the air bag light pinged when i removed connections!
anyway apart from stealers to delete the fault? cheers
You can buy a fault code reader, I picked one up from eBay for £30 and it worked on our tt. It might be worth Irving people an idea where you are just incase someone can reset it for you, I'm Peterborough if that helps.
