Tinlad
Hello!
Completely new here, so I hope I'm following the correct etiquette for asking questions. I've searched (both the forum and Google) for an answer prior to posting and haven't found anything.
I've got a 2003 Ibiza S (1.4 petrol) with a bit of a problem with the air con:
- If it's set to the minimal temperature, I get very cold air.
- If it's set to any other temperature, I get extremely (uncomfortably!) hot air.
The air con is controlled via three manual dials. All the controls except temperature seem to work as they should. The problem exists whether the 'AC' control is on or off.
My hypothesis is that it's not detecting the cabin temperature accurately, and thinks that it's much colder than it is, and therefore shovelling out air that's as hot as it can manage. The exception is when it's on the minimum setting, in which case it ignores the cabin temperature and just gives cold air.
Does that sound plausible? If so, any suggestions for a fix?
Many thanks in advance for any help you can give.
Cheers!
Cheers!
