Alba ICS 104 Radio Code -- Any radio buffs?
Israar
450
Dudley
Hey peeps! :)
I've been looking through my documents and even had my radio out without disconnecting it and can't seem to find the code for it. As in the code to get it to work again if you disconnect it from the power or battery.
I have found a 4 digit set but would like clarification on weather I am right to believe that it is the radio code I need. I believe that it is the 4 digits above my finger on the right sticker at the bottom next to the post code? If not then I don't have a code for the radio, would my next step be to get a new radio or is there any way to recover a radio code without it's documentation?
Thanks for reading! :)
--Lee
Israar
450
Dudley
Thanks Dan and Bouncer!
Not sure if it actually needs one or not, but given the link BouncerBeater provided it looks like the 4 digits are the model number haha!
I'll try it tomorrow by unplugging it and plugging it back in, if it doesn't need one great, if it does then I might just buy a new one and the two side panel bits to make the radio sit more neatly and look more decent rather than have the sides of it look poor by it not fitting the entire unit! :D
Again, thank you for the replies! :)
--Lee
