Yeah they do look good when done , I've got black and white vinyl infront of me , Word of warning the black vinyl is harder too use than the carbon as its much thinner ! ... But behind the plate is so easy too do mate.. hardest part is takeing the insert / grill out and back in the bumper.. What a chew on that was..
Basically cut it too size with about 5 mm extra too overflow the edges.. flat the middle with a card so you have no bubbles then get a hair dryer and heat the edges,they will tuck down the sides perfect!
Then let the corners get a little overlap line and cut each one with a knife or your choice of weapon
, Then push the overlapped edges into the side they have heated around with a credit card too create a smooth edge .. Hope that makes sence? Any
problem ask me and ill
help you! atin
