Alloys and Suspensions
Sep 3, 2020
16
Ni
Looking at 19 inch alloys for my leon probably be on 235/35 tyres, Does anyone else have 19 inch alloys and have Coilovers or springs in if so what mm are they at to prevent any rubbing on the arch etc?
Damo H
4,707
2,817
Car Length In Front
There is a lot to consider when thinking wheels and lowering etc.
So wheel width will have an impact on what offset you can run with lowering springs.
19x8.5 ET45 with 235/35 R19 Tyres is a safe bet for lowering and what Revo and Racingline recommend for these cars.
OEM wheels are 19x8 ET50, so the 235/35 R19 tyres sit squarer relative to the wheel. So although a 10mm spacer may give the wheel a similar poke to the 19x8.5 ET45 wheel, the tyre is more likely to rub.
Your best bet is to aim for 19x8.5 ET45 or use that as a safe basis and compare using the link below with what you like, to see how much of a difference there is...
Reactions: ryc1 and CairoCupra
