OneGearAtATime
Went and bought a Sub with built in amp these are the details:
1700 WATT MAX
450 WATT RMS
92 db/W/m
STEELBASKET
4-layer ASV
40 x 30 x 35 cm
4 Ohm Impedance
Frequ. Response 50 Hz - 250 Hz
what amplifier wiring kit should I get? I know a wee bit about the different size cables etc but don't want to buy wrong one
Also behind the stand aura CD player will I have to get Y connector for RCA cables so I can listen to music through door speakers as well
You will get a lot better quality if you swop your head unit to a sub per out unit instead of using the y connector to gain RCA outputs, this idea certainly works but not to the best if you like clear quality....
Sent from my iPad using Tapatalk HD
Thank you for reply, next question then does it matter what CD player I get
