dino9999
31
hello, i have an annoying rattle from my engine on low revs wen in high gears in lowish revs,wen i put more revs it goes away, it never used to do this untill had a new bearing on cambelt shaft,any ideas?
forgot to say its a tdi cupra
Sounds like something's loose to me. Does it sound like metal or plastic?
thanks, wheres that and how do i get to it,sorry to be a pain,thanks
Well a good place to start would be under the bonnet :whistle: If your car's had work done on the engine then the chances are that the garage hasn't tightened something up properly. When the engine's cold just open the bonnet and look for any bits of metal and check that they aren't loose. Also check for loose heat shields on the exhaust system. If all else fails take it back to the garage and complain!
