mofid wrote
Okej, it is a petrol engine, accedently i descovered the FPR, here is whats happning,
Well, this is the diesel section of the forum, so you aren't in the right place, really. You might get some answers in the Toledo section. That is the most likely place to find another Mk.1 Toledo owner, for sure. However the Toledo section has less visitors, reflecting the lower number of Toledo's out there.
If I understand you correctly, you have now found the fuel pump relay, is that correct?
for a while ago about 1 year the car began to cut off totaly like you turn off the igniting all the lights are on on the dashboard and was very easy to start again,
Again, if I understand you correctly, the car is just cutting out. Does this happen while you are driving, actually in motion on the road? Scary.
When it cuts out, do the lights on the dash stay on or all go out?
How do you get it to start again, by turning the ignition all the way off, then back on again?
with the time it began to not start sometimes and that was the FPR which does not getting pwoer when i turned on the engine AND tried to crank,
Are you using an electrical meter to prove that the Fuel Pump Relay is not getting power, or just listening for it clicking?
i tried to push the relä manuely just to see if there is the problem but it did not help, the FP goes fine but it will not start,
If I read this right, you tried manually closing the contacts on the fuel pump relay (Bold - must have the cover off and know just
how to apply the screwdriver to close the contacts without shorting everything out).
When you do this the fuel pump works but the car still won't start.
now seems like the ECU ´does not get or miss the trigger from the triggersensor,
Well, I think there is something more than just the fuel pump relay at fault. But it is hard to work out what.
I think that if you can get the car diagnosed using VAG-com or something similar, to find out what fault codes are being raised, then you can maybe have a chance to find out what is causing your difficulties. A Seat, VAG or good independent dealer will be able to plug your car into their diagnostic equipment, but is likely to charge you for doing so. The alternative is to find someone near you who has VAG-com and a suitable lead and who is willing to come and
help you.
Where are you located?
