much more the type of answer i was looking for and thanks for taking the time to work it all out...
this is also useful in the future for anyone else that comes across the same problem and is also proof just because they are 4pots doesn't mean they are better..
i was planning on using them on my 312mm discs the standard brembo pads that are new and obviously braided brake lines ... running 312mm with oem pads at the moment.
So we can probably say that the distance of the piston to the centre is similar and the pad friction co-efficient will be similar.
So all in all, it'll take a slightly harder pedal press to achieve the same braking as now.
New pads and fluid compared to old stuff will probably counteract this, and 4 pots will apply the pressure more evenly than single pot calipers.
Seems like a lot of effort to me for not a lot of results
