Hello everyone
I'm interested to upgrade in the near future the oiling system on my LFR, to aid in engine lubrication during sharp corners and first and foremost for the protection of the engine bearings. There may be the last set of mechanical mods to be performed on the engine.
It will take a few months to save the money needed, so it's a long or medium term project.
The car's engine mods and performance are listed here:
http://www.seatcupra.net/forums/showthread.php?t=246139
http://www.seatcupra.net/forums/showpost.php?p=2896139&postcount=40
Current state of the car:
- ~73 000 kms from new (~45 000 miles);
- new exhaust valves due to broken cambelt incident;
- new piston rings fitted during the same overhaul;
- Pipercross oil catch filter (not tank), but it barely catches a few cc's of oil;
- no visible signs of oil consumption.
Current plans:
- Baffled (and aluminum-plate-armored) oil sump from Jabbasport or Backdraft Motorsport.
- Crank scraper from Rosten Performance.
- Fluidampr.
Crank scrapers are said to allow better engine performance and oil flow during continuous high rpm, due to less of a mass to be spun by the engine. An ideal construction would be a scraper with Teflon blades, but I've not found any for the 06A blocks, the easiest to get option is the steel-bladed scraper from Rosten Performance.
Which disadvantages may I get from fitting together a baffled sump and a steel bladed scraper? May the scraper, even if properly fit, hit or grind the spinning crankshaft sometimes in the future? May the valves of the baffled sump break down and block the flow of oil to the oil pump? Does the pump experience greater effort in sucking the oil from a baffled sump compared to a classic open sump?
And, even if all fit together perfectly, how would it run compared to a dry sump engine (which on a 1.8T is outside the realm of possibility due to cost)?
Thank you,
~Nautilus
Current plans:
- Fluidampr.
Thank you,
~Nautilus
