It can get a bit confusing removing individual fuses as some will be for the "controller" and some for the loads it switches.
Maybe try removing the alternator output lead and cover it to keep it isolated, doing that will check if the alternator is to blame.
I think that
@300bhpdaily's question about the battery light would also be valid as "check the battery warning light is on with only the ignition key in the first position" ie is the control cabling to the alternator still okay - but you have said that the voltage is around 14V so maybe that is good enough.
One way to check the battery drain after all the systems have been forcing into "sleep", is to connect one side of a current meter to a body earth point using a crock clip, using a straight sharp probe, push that down onto the -VE battery post and while holding that down, slacken off the battery negative and ease the lead up over the straight probe - doing that after leaving the car with doors closed and the bonnet open for maybe 20 minutes should let you see the true "sleeping" drain current which should be around 50 milli amps.
Ideally you will have all the car's wiring information and find that hopefully there are 2 distinct areas of the car that you can separate so that you can start further isolating local areas down a bit more. I seemed to remember being able to do that on my daughter's late 2009
Ibiza when chasing current drain, but in that case I was just proving that it was a BCM
coding patch that had never ever been applied to that car - which in the end it did turn out to be!
Edit:- removing the central locking fuse will easily remove it from the equation, you can lock up these cars manually with the power removed, in case you didn't know, all the doors without a lock barrel will have a manual locking point under a rubber cover on the "door face" you just use a key blade etc to flick the manual locking part over and close the doors.
