becketttimmay
oright can anyone help me with this before i take things apart,, whenever i turn the ignition the computer makes a bleeping noise as same a seat belt warning, and low fuel!! how do i stop this,, is it to do with resetting the system?? faulty wires?
cheers
is there a light flashing on the dahs.....by the temp?
if so its the sender in your collant bottle either knacered or just needs scraping off with a screwdriver...happened with my old mk3...
just open up the coolant bottle (when cold) and you will see 2 prongs of metal, scrap them with a screw driver a bit!
See if that helps?
