hi all ive read alot about ppl doin this but what are the benifits as im giving my car a good goin over a weekend was gona do this but if it dont do anything whats the point lol. pros and cons please thanks
I have bypassed the N249 (but still connected) and removed the vacuum reservoir and ran the DV straight off the intake manifold. The DV response is so much better, slightly louder too but you won't get any performance gain.
Plus all the rubbish is removed from the top of the engine and better access to the coil packs.
^ Exactly.Why do they do the bypass then? I have mine still, but have toyed with the idea of losing it. Surely if it's on there, it's there for a reason.
The original reason (from a 6 year old thread on VWVortex)
Lol at some of the comments, removing the PCV is one of the best things you can do to a 1.8T proven time and time again, the fault codes can be eliminated by a simple resistor and now with the advancements of Bosch Me7.5 tuning, can be mapped out.
1. Less leaks
2. Less crap to break down and replace
3. Less clutter
4. Easier to located possible future leaks
5. Better DV response
6. Better throttle response
Man this forums changed a fair bit since I was last regularly active.
No Pcv delete removes the pipes from under the manifold.
249 bypass doesn't.
