One good thing is that Cupra R has 19 inch wheels so when you put lowering springs, it is not as low as if you had 17 inch wheels for example
I had a VW Bora Mk4 1.8t before driving the cupra with Oem 17 inch wheels and H&R Race Springs. This car was very very low.
Dos anyone know what kind of sway bars has the cupra R? Or what differences are between Cupra R suspension vs Cupra and FR? I tried to buy sway bars but the seller told that this wont be an upgrade to cupra R only for FR o cupra (eibach sway bars) ?
Anyone???
Last message:
Dos anyone know what kind of sway bars has the mk2 cupra R? Or what differences are between Cupra R suspension vs Cupra and FR? I tried to buy sway bars but the seller told that this wont be an upgrade to cupra R only for FR o cupra (eibach sway bars) ?
Enviado desde mi SM-G850M mediante Tapatalk
It'll be the same height as any other mk2 Leon as both wheels have the same overall radius with a tyre fitted
Its a little bit different. Check this
FR 225 45 R17 diameter 63.3 cm
Cupra 225 40 R18 diameter 63.7 cm
Cupra R 235 35 R19 diameter 64.8cm
Ah OK, I was assuming running a 225 width throughout, to minimise speedo error
E10-81-009-04-22 or E10-81-009-05-22, which ones is right for my -06 leon tfsi?
These are the pro kit is also look at the sportline also bear in mind the quoted drop is based on a std Leon if your tfsi is an fr the ride height is already lower by around 15mm this needs to be subtracted from the stated drop i.e. Pro kit states 30 (15 actual) sportline 50/40 (35/25)
My leon is normal, not fr, so ride height is normal and i want even drop. Little bit more researching and the right answer is E10-81-009-05-22.
If you want an even drop get the H&R springs, 40 mm all round on your car
Yes...eibach are cheaper and handling is great...I have ridden H&R race on a Mk4 Bora and Eibach Sportline on my cupra. Both area great springs.
This is my cupra with eibach sportline :cool:
Does anyone know how does 18x9" offset 35 wheels look like on a mk2 cupra R? I am planning to buy new wheel but there is only 18x8 or 18x9 both ET35. I dont know which to choose.
