BHP calculating
caveo
I think i read that vag-com can calculate your bhp , which blocks to i use and how do i work it out??
caveo
Right mate iv been and done it and the best i can get is 227 g/s which is 280 bhp ( x 1.25 ) so now im worried . No fault codes and i cant see any loose hoses or split ones.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
block 120 was the original torque figure. log that and rpm and you back calculate bhp
( as said, meaningless once modded)
caveo
i used block 77 rpm and mass air in ( best was 227 @ 6400rpm )
May 25, 2004
2,691
Newport, South Wales
forget calculating it from MAF for an accurate reading. Found a post from Bill a while back, plenty of threads out there on this.
Quote:
Originally Posted by Feel
Sorry Bill - I've read this post a good few times and I don't understand...
Are you talking about the 1.31 * g/sec = HP calculation, or something else?
kinda the same thing... scaling in factory ecu's is not the same, so comparisons with x g/s = a power output can at best only be a guide.
internal scaling of maf being different between ecu's, let alone various "tune" ones
caveo
well im having a service on friday so i'v asked em to take a look.
jcc-gttdi150
www.torqueoftyneside.co.u
The formula I was told to use for bhp using vagcom is below but you'll need to log rpm and torque as a minimum from the blocks. torque in Nm is block 020 on mine.
First, you'll need to convert the Nm torque to lb/ft, which is done by multiplying Nm by 0.738
Then you use this:
bhp= (rpm) * (lb/ft) /5252
I did and then used the excel graphing to create this graph
207bhp and 302lb/ft, which is nice:funk:
