Car Surges slightly then hesitates for a couple of seconds then boost settles back down again.This only happens in 4th and 5th gear (five speed box).
Run was done in third and car has just been remapped, this is when the hesitations started.
After changing into 4th for about 2 seconds then when i change into 5th again for about 2 secs,Its a little worse in 5th. Happens quite early in rev range about 3000 rpm.
Have already changed N75 made absolutly no difference, Both were F version
seen all this before you look and look for the fault and its normally down to maf problem,even though it says its o.k. doesnt mean that it is. done 100's of them now some totally gone some like this
Could have just coped the filed from excel into here with code tage in between. lol
Your maf looks fine, but slighly could be better (e.g air filter, cold feed).
You boost seems fine, but why is tailing of earlier , after 3500rpm.
who did your remap?
any logs for the CF, the fueling?
