Roccatmode
Hi all,
I have an Altea 1.9Tdi 105PD.
As standard all was well...So, I bought myself a BMC CDA induction kit, and fitted it.
I bought a 45 degree silicone elbow, with 5mm self seal take off, for me to attach the crank case breather pipe to. I had the air ducting positioned in my fog light hole so air would be forced in towards to BMC CDA.
I thought all was good, I could hear the turbo spool up nicely as it went in out of the boost range.
But I started noticing something strange. Whilst slowly accelerating through the gears when ever I reached 2,000 rpm or normally just before this, the engine would seem to hesitate. I can't explain it really, but it felt as I reached 2,000 rpm during slow acceleration it would seem as my throttle was being jumpy. This seemed to happen more often after a longer drive, and normally only in second and third gears. However today I noticed it in fourth and fifth whilst accelerating on the motorway and my revs were below 2,000 rpm. However, I don't experience any of this, if I floor it, even from a standing start and the revs are below 2,000 rpm.
It was doing my head in so much that I decided to revert back to the originally filter box set up to see if it was a result of my BMC installation.
After doing so, I test drove it, and for the life of me I couldn't replicate the above. Okay I didn't have a cold air feed to my fog light area making sucking sounds, (which when the BMC was installed would give a audible recognition of the hesitation, like a suck, pause, suck, pause, suck sound even with a constant acceleration) but I didn't even feel any jumpiness or hesitancy from the engine.
I can't understand why the BMC could do this? Is it because it's feeding to much air into the engine and the MAF can't keep up, so in other words my MAF is failing, or does this sound like a dead spot in my rpm range that would be rectified when I get my map done in two weeks.
I don't want to give up on the BMC, it cost a lot, what should I do?
Hope you guys can help.
