bonnet lifter guide
gregorsco
leon mk2 fr tdi
Aug 17, 2011
353
lower largo fife
hi all i just bought a bonnet lifter kit from a mate hes on here called asquith_4 just pm him for kits and all your led needs including full car led kits,hids everything
this is my install guide
what you need: 2 ball joints with washers, 2 nuts ,3 large washers and of course the strut
tools: glue, small screwdriver, appropriate spanner/ double depth socket
1st glue your nut to the large washer x2
2nd attach the ball joints to the car at this position
3rd the second ball joint
for this put a screw driver through the middle of your glued nut/washer then manouver the washer side to side till it is behind the slot. with your free hand hold the washer whilst removing the screw driver.(this is wy we glue them so the nut doesnt fall inside the car)
then screw in the ball joint with washer and the spare large wash .like so
4th connect the fat end of the strut to the lower ball joint
5th remove the bonnet holder then move till the top a lines with the top ball joint and engage.
then carry out a test to make sure it all works . i had to bend the lower ball joint so it tilted back a bit .
asquith_4
Fr -260
Feb 15, 2012
41
Cheers for mention mate! Anyone needs anything let me no :) bonnet lifter just £15 with all fitting ;)
will21
Newbie
May 13, 2005
26
Hi asquith_4,
Do you still do the bonnet lifter to leon mk2 1P?
Sorry for posting on a old thread. Couldn't see an option to send a PM.
thanks
