I have read recently that some members had difficulties releasing their bonnets. Recently mine had started to stick.
The issue here is the lower pivet point on the left had side of the mechanism (as you look at the car). It looks remarkably like a rivet. Having squirted WD40 at it and rocked the main catch side to side this weekend a fair amount of rust coloured WD40 seeped out from this pivot point. Had this pivet point seized solid then it would have been an absolute sod to release the bonnet.
My advice to all members would be to do the same with the WD40 and work out this corrosion before the salt gets laid down and potentially make the matter worse. In the next day or so I'll spray some grease there.
To release the bonnet I had to use some pliers on the grill release tab (not something I was comforable with).
A two minute job could save a lot of grief as anyone would know whose had to release a locked down bonnet.
