So before Donny show i had the intention to build a false floor to put my subs on and to neaten off the rear inside... but since almost lopping my whole finger off and having it in a splint for 5 weeks, things got slowed down a fair bit.
But now i can move it... all be it only a very small a mount... i have continued where i left off from building it
Ok so the idea is a false floor with a window for an amp in the back section, with the amp recessed under the floor, and a flat floor, from the back of the seats to the rear of the car with the sub box behind the seats.
Pics of it as it is and it will be updated as and when... should all be in tomorrow, or early next week
Firstly the structure was made... i tried to keep glueing to a minimum, and used as many of the threads already in the car to bolt the frame to.
Made a box for the amp to go in under neath the false floor.
Cut the panels out of MDF to the EXACT shape of the car
Carpeted everything with acoustic carpet, and cut the holes for power cable and speaker cables etc...
Carpet was stuck on with spray adhesive and heavy duty staples
Heres the back panel carpeted, with the hole for the perspex window...
The back half of the boot is finished
Ill update with the finished pictures as and when...
Just thought id share my small project
