Boot Gas Struts
Webstuff72
481
101
Milton keynes
Same here. The boot struts along with the door release badge and now the petrol cap solinoid all get a good dosing of silicon spray.... Don't use wd40 people.. That's a releasing penetrant. It will work for a short time then gum up and make things 10x worse... Invest in silicone spray.. Including down the sides of the door/window runners.. Help with windows sliding up and down..
Deleted member 103408
ok i will have a look later. - well wont now as Wastedagen had given you answer.
Webstuff72
481
101
Milton keynes
is silicone grease the same as plumbers grease?
Don't know my friend... I just use something like this....
RichardB101
Hi Guys,
I am new to the forum. I have just taken delivery of my new Seat Leon Fr 1.4 EcoTsi 5 door, 2018 plate , great car so far.
I have done some Carista changes, nothing special as of yet. But my next job is the go for the auto pop boot. Because i am on the 5 door model what length of strut would i need? I see someone above mentioned for 3 and 5 door the length needed is different. I also assume i will need 515N as a min.
Thanks in advance :coolthumb
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Hi Guys,
The struts for 3 & 5 door are the same, it's the ST that is different. The type you need is above.
jacko5
187
35
61
UK
I bought some of the skoda ones listed in the thread earlier and they did not fit my 3 door SC Seat Leon.
I had to get the 483mm ford focus ones from Ebay.
They fit great but did not lift the boot even though they are 530N.
I put a 50mm spring onto one of the boot struts, and now the boot pops every time.
kazand
Jun 6, 2010
4,138
73
Brum
Not sure why you had issues, the standard Seat strut is 494mm long, 183.5 stroke, 410nm force. The Stabilus ones listed ( and I have had fitted to previous 280 and current 290) have a length of 492mm, stroke of 184mm and a force of 515nm. They are for the Skoda Octavia. They lift the boot fine from the key fob.
Reactions: heliophile
GTunney
270
21
Newcastle Upon Tyne UK
I hope the ones I’ve bought fit. Just noticed they’re 515mm, 184 and 515nm of force.
bremner97
18
Apologies for bringing this up again, but can someone point me in the direction of the correct ones to buy? Quite a few different links being thrown around and unsure which to order...
And on my 280 they fitted with no issues at all in the same way as the original items
