bottom beam
moonman374
121
alright guys
thanks for your help with my parts list
need help with 2 more parts needed so my body shop can sort it. firstly i need the bottom beam? its at the bottom of the front obviously. in the center it has like a circular piece that may be an engine mount. mine has moved/popped out as you can see in the pics below! so need that long metal bar type thing cos its bent. plus there is like a plastic protective pieve on the bottom of the radiator which has gone so need that part number also
cheers guys
http://img.photobucket.com/albums/v116/moonman374/Photo-0786.jpg
http://img.photobucket.com/albums/v116/moonman374/Photo-0787.jpg
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Looks like the front engine mount.... I think there is meant to be a gap. too dark to look now.
moonman374
121
thought that was an engine mount. I am 90% sure it has moved as there is a clean ring where it had obviously sat not allowing dirt in. I am after not that part but the big metal plate that goes under this
moonman374
121
well as you can see it sticks out quite far now. need to get this bottom beam and any plastic protection that fits on the underside
