Right I'm no good with brakes, so if anyone could help me that'd be awesome!
The problems started when I changed my rear pads, I found the braking efficiency to be down, the handbrake now goes up a lot further and only seems to hold one side and also found that the servo made hissing noises when I let off the pedal.
Now, when I brake medium to hard, I find the brakes make a whirring/grinding noise and the car will feel like it might not stop. The hissing noise seems to be apparent when I press and depress the pedal so I think the servo's knackered. I checked the pads and they're still full of meat, the discs aren't scored anywhere, and its lost a bit of fluid since I last checked it, not a lot at all so that could just be normal usage.
Any help would be terrific, I don't want to put the Ibiza back on the road just yet as I wanna change the clutch cable and finish the ICE off. I also don't have any front indicator lenses, so running it would be kinda illegal.
Cheers!
Cheers!
