Bulb warning in dash FYI
irl_techie
58
I discovered I had a blown headlight bulb this evening (H7) and noticed that the dash warning light did not come on?
It has come on previously when one of my rear lights was out???
Joe_3490
404
Hmm, I have only ever seen that light once, but when I looked it up and saw which it was I checked all the lights all working fine, and its not done it since.
Maybe the Check bulb light is broken :D:D
irl_techie
58
That happened to me with my back light, the bulb lit on the dash and I had no light not working.
But then I tapped the back lights on the car gently and one of them went out, so swapped that out and have not seen the dash light again since.
Bit strange though it does not pick up the fact that a main headlight is not working?
67igor1
Herts
The tail lights are under voltage control unit... All other lights can be monitored by taking on options in adaptations in the Instrument Cluster (IC). If will be on you can not use LED bulb.
