For
OBD11 The following settings are show
Expanded XDS electronic differential lock
We may change the way it works, you can choose between several values in a way that best suits our driving.
1 - Module 03 - Electronic brake. Code (40168/20103)
2 - Adaptation
3 - Select - Electronic Differential Lock Expanded
4 - Activate one of the five options:
- Standard (default)
- Central
- Not activated
- Weak
- Strong
Personally i have this set to Strong
If you are looking at changes setting have you also looked at the following
http://www.seatcupra.net/forums/showpost.php?p=4727866&postcount=43
And here are a couple other tweaks you can apply that may be of interest.
ESP depending on the speed
Applying this modification can activate the ESP function acting on the speed that take the vehicle or the value is always fixed.
2 - Adaptation
3 - Select - Electronic Stability Program
4 - Select one of the two options:
- Activation function of speed
- Not enabled (default)
- Activated
ESP multimode
Applying this modification can have multiple ESP and ASR options depending on how we program.
2 - Extended
Coding (byte mode)
3 - Byte 29
4 - Bits 0.1 and 2 Activated shows: Activated - ASR disabled - ESP off.
5 - Bit 1 Enabled shows: Activated - ASR deactivated
5 - Bit 2 On shows: Activated - ESC disabled
6 - Bits 1 and 2 shows Activated: Activated - Sport ESC - ESC disabled
7 - Bits 0 and 3 On displays: - On - ASR disabled - ESC Sport.
Disable ESP and ASR
With this modification permanently dasactiva the ESP. I do not recommend it, I do not like.
2 - Basic Settings
3 - Select - Deactivation ESP and ASR
- Activated
