Caliper paint
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Hammerite works a treat, it drys quick and covers in 1 coat (unlike the expensive so called proper stuff) The calipers don't really get hot like drums do so hammerite is fine.
vroomtshh
4,222
Dreghorn, Scotland
I used Ford radiant red spray from halfords that I had lying around
I personally don;t like hammerite. Brush on stuff never goes on nice, and the spray takes about a month to go hard
Jan 11, 2005
680
Barnsley
Hammerite smooth spray. Rub down, 3 decent coats, let it go off for a couple of hours. Job done :D
barney501
1/4 mile - 14.75 @ 92.84
Oct 8, 2009
176
Bath
Did you take your callipers off to spray them mate? They look really good. I usually paint mine with high temp engine paint then use a stanley knife blade to cut the "seat sport" letters off once the paints dry and hard.
Jan 11, 2005
680
Barnsley
I left them on but the caliper bolts were removed as I was changing the discs and pads as well which allowed me to move them around. I cut the soft paint off the letters and after a week I put some fine wet & dry paper on a flat block and polished the paint residue off the letters.
If anyone is spraying them on their car make sure you mask off most of the car!
