CupradanM
Is it easy to remove the calipers from a leon cupra?
Thinking of painting them red on my black cupra, hammerite paint okay to use?
Thanks guys
caliper removal
undo 2 hex key bolts top and bottom, guide pins, undo 2 bolts onto the caliper carriers
the caliper will then push off to the outside of the disc, remove the pad pin and the pads.
easy as that mate.
hammerite is fine, make sure you clean with wire brush to remove all the crud first, careful on the brake lines not to stretch them
caliper removal
easy as that mate.
Okay mate thanks will be giving this ago at the weekend :p
caliper removal
easy as that mate.
i agree with all of that (mines are brembos so i dont actually know but sounds like a man who has done this before lol!)
only addition i have is to also use proper brake cleaner spray, the stuff is magic! iv just refurbed my callipers and the spray saved lots of time and effort
