Cam Belt Stripped - Likely Damage?
dirtbiker
274
Southampton / Nottingham
Hey all,
Last night I managed to strip the cambelt teeth on my 1.4 and I was wondering if anyone has any idea how much damage there's likely to be (all my tools are at home in Southampton and I'm at uni in Nottingham so I can't have a look at the moment!)
Basically what happened is I stopped at some traffic lights and the revs fell straight to zero. Tried turning it over a few times but no luck (obviously). I'm guessing that there will have been some valve-piston contact but is this likely to have damaged the pistons or just bent the valves?
If I can get away with replacing the valves or the head than that's probably cost effective but I'm not sure I can justify an engine swap (as its the base model anyway so no electical goodies, which I'd like!)
Any thoughts until I get my tools up here to see for myself? ;)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
probably just some valve damage, maybe the cam's too
I have a complete 1.6 8v engine in my garage, and the head will be the same - and you're welcome to it (head only if you want)
if you were idling the damage will not be too bad.
