smithcupra
hi i need to set my camber and wondered if anyone knows what the degree/measurment is? thnks
it should be the agg engine
Notes Specified value Measured value
Wheelbase mm 2440 Track - front/rear mm 1429/1394 Tightening torques
Tightening torque - steel wheels 110 Nm Tightening torque - alloy wheels 110 Nm Trackrod locknut/clamp 50 Nm Checking range - Front wheels
Load positioning Unladen Fuel tank - percentage full % 100 Toe-in (N = negative, toe-out) mm 1N - 1P Toe-in deg 0°10'N - 0°10'P Toe-in deg-1/100 0,17N - 0,17P Camber deg 0°10'N - 0°50'N Camber deg-1/100 0,17N - 0,83N Castor deg 0°56' - 2°10' Castor deg-1/100 0,93 - 2,17 Setting data - All wheels
Load positioning Unladen Fuel tank - percentage full % 100 Toe-in (N = negative, toe-out) mm 0±1 Toe-in deg 0°±10' Toe-in deg-1/100 0±0,17 Camber deg 0°30'N±20' Camber deg-1/100 0,50N±0,33 Tolerance left/right deg 0°30' Tolerance left/right deg-1/100 0,50 Camber adjustment Adjustable*** €
Castor deg 1°33'±37' Castor deg-1/100 1,55±0,62 Tolerance left/right deg 0°30' Tolerance left/right deg-1/100 0,50 Castor adjustment Not adjustable Toe-out on turns at 20° deg 1°20'±30' Toe-out on turns at 20° deg-1/100 1,33±0,50 Manufacturer: Seat Model: Ibiza (93-99) 2,0 Engine code: AGG Output: 85 (115) 5400 Tuned for: R-Cat Year: 1996-99
Rear toe-in mm 2±1 Rear toe-in deg 0°20'±10' Rear toe-in deg-1/100 0,33±0,17 Rear toe-in adjustment Not adjustable Rear camber deg 1°30'N±30' Rear camber deg-1/100 1,50N±0,50 Rear tolerance left/right deg 0°20' Rear tolerance left/right deg-1/100 0,33 Rear camber adjustment Not adjustable Camber adjustment
