camber kit
tomwcupra
114
hi
i have now got my car nice and low but i want more camber is there any type of kit out there to add camber to the ibiza cupra ? i have looked all over the internt but carnt find anything :(
any help would be appriciated .:D
vroomtshh
4,183
Dreghorn, Scotland
Front or rear?
Front, you can gain camber by slotting the bottom ball joint mounting holes, or by slotting the top mount mounting holes.
Rears you can remove the stub axle and re-fit it with washers behind
tomwcupra
114
hi both ends mate i understand the adding washers for the back end but was dose slotting mean for the front end and how do you do it ?
thanks tom
Jul 11, 2009
643
Dorking
I use LESS camber (ie. make the front wheels MORE upright) - if you've seen my on track video you would know this works. Adding MORE camber will destroy the inside edge of your tyres.
tomwcupra
114
I see what u mean by the tyre ware but I have some 18inch wheel and need camber to make the fit right :/
WJs
MeepMeep
Oct 26, 2006
497
Netherlands
What specs do the wheels and tires have?
I have 18" and lowered it and no problems at all.
