Can you fit LCR bolt style shaft hubs to cupra shafts with hub nuts ?
spudboy6
721
114
Swindon
Hi all , weird one I know hear me out
I’m doing front end swap so whole lot subframe arms rack hub the lot
My new lcr set up uses bolt in drive shafts instead of the older style hub nut shafts ,
Now my car currently has hub nut shafts , what’s my best options ?
1- Change cv joints on my original shafts to lcr bolt style
2 - buy lcr drive shafts
3- change wheel bearing over and use old hub face (where wheel bolts go into ) and retain hubnut style
Really I’d like to Keep things simple and minimise car down time so either two new shafts (can’t seem to find any new lcr shafts at euros or gsf ?)
Or change cv joints on current shafts when subframe is out with lcr bolt style
Or is there a simpler way I’ve missed ?
Just found online j&r do the shafts for reasonable money anybody tried and tested their shafts ?
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
Does your drive shaft fit all the way in to the lcr hub ?
Is the inner hole in the bearing where the drive flange (where the wheel nuts goes into )goes into the same size ?
spudboy6
721
114
Swindon
I’ll have to have a look .
Can’t compare as one still fitted to the car , one on the floor .
I’ve compared and checked the wheel bearing sizes they are the same .
But I think the front of the flange (where wheel bolts goes into ) is a different size and shape
Yellow fr
Sep 6, 2018
1,547
1,062
I have used j&r drive shafts as I’m in the trade
Not had any issues
If your wheel bearings are good you can just use your hub with the new set up that your putting in as there are the same I think the only difference is the drive flange from the cupra and the lcr but I’m not sure
