Gertwin
My original SEAT multichanger has went on the blink and it will just not work at all.When i press CD on the Aura radio cassette it just says 'changer' and nothing happens,no noise or nothing coming from it and i have also checked the wires and all seems ok.
Is they're anywhere in the Glasgow area who can fix them or can someone give me any tips how to try and sort it myself.
PS My cd's are stuck inside the cd rack and i want them out!!!! [:@]
If under warrenty go to dealer, I'm waiting for my new one to arive, if not might still be worth going saying these are known to be prone to faults and chances are it was likely to fault when it left the fatury it was just a case of when, o.k if within warrenty but you should not be prejudiced simply because it happened to last a little longer etc
Have you tried unplugging the wiring from the back of the changer and plugging it back in, while the unit is turned on? Sometimes this can make it check itself and start working again.
