potter88
377
Norwich
Ive got to change my wing mirror due to someone damaging it.
I've heard it can be done from just accessing the speaker cover but i think i might make life a little easier by removing the door card.
Just wondered has anyone got a pic of all the screw locations to remove the door card??
There's a thread on here of how to remove the door card use the search function......
I replaced my mirror after getting it knocked off and was going to do it by removing the door card but it seems like a royal pain to do.
The easiest way is to remove the speaker and reach up to access the mirror takes 10 mins!
Sent from my SM-G920F using Tapatalk
That's what I've seen too. Is it relatively easy through the speaker whole??
Really easy if I remember you need a ratchet 15 or 17ml socket and a extention
Take the speaker cover off and remove the speaker
Put your arm in and up and feel for nut on bottom or mirror and use ratchet/spanner whatever's easy to undo (all you need to do is undo it a few turns and you should be able to do the rest by hand)
unplug the connector for the electrics in the mirror you will be able to feel where they join then ta-da it's off! Easy!
