Has anyone encountered that the lights doesnt work, even after changing to new ones?
Mines gone Dark, no power in the holders. Guessing its some broken cable near the hinges.
A switch would have gone out. Need to look at the ecu port and access it to reset it.
You were absolutely right.. I connected my vcds to the car and there was a fault code on the license light. Short, + to negative, it said. After a while i found that the cause was one of my ebay canbus led-bulbs. It works perfectly with other leds and halogen, but as soon as i connect that very bulb the power cuts and the code appears.
So, new set of bulbs, deleted the code and now it works!
