Chips
Nov 12, 2019
Hi all,
Have had my Leon MK3 Cupra 7 weeks now, got it just before lock down and it's got a chip on the bonnet already. Anyone recommend any chip repair kits, it's in urban silver.
Thanks in advance,
Lewis
Rowan83
241
82
I just bought the touch up pen kit from SEAT which includes lacquer.
Use a cocktail stick or fine artist brush to apply the paint in several layers. When fully dry apply the lacquer, leave to dry and rub down using wet and dry. Polish the area to remove sanding marks.
You could also try the Chipex touch up kit, it's supposed to be quite good.
Mine is Urban Silver too.
SRGTD
2,433
1,313
I’ve used the Chipex kits. An alternative is the Dr Colourchip kits which are pretty much the same as the Chipex kits. They are more expensive than the Seat touch up pen kits and they take a little practice to get good results (there are ‘How to’ videos on the Chipex and Dr. Colourchip websites, and on YouTube), but the beauty is that if you’re not happy with the results, it’s easy to remove the paint you’ve applied with the supplied blending solution and then start again.
I used to find the paint in the Seat touch up pen kits can become thick after a few uses - when the cap is removed so the paint becomes exposed to air. When this happens, it can become difficult to apply without the application becoming ‘blobby’. I’ve not had this problem with the paint that’s supplied with the Chipex kit though. As @Rowan83 has said though, always apply with something like a cocktail stick (the end of an unfolded paper clip works too), rather than the in-cap brush in the paint pen if you’re looking to get good results, and build up the paint in the chip in layers rather than apply one thick coat of paint.
