MikeFr
54
Seen these on ebay 130740967913. Look like they might fit on fr tdi.
Anybody know or can tell where to get some
you would have to contact them to ask what the internal diameter is then measure your outside diameter yours need to be about 1.5mm less you can get them from majority of car shops and halfords
MikeFr - I have asked that seller and this is his reply:
"Hi - Internal diameter of the pipes between the clip fixings is 55mm (although this can expand a few mm more), the length at the longest part is 90mm and the length at the shortest part is 70mm
Regards
Shaun
(walkerboy15757)
Hope that helps,
Bernard. :D
Thanks for the info Bernard. I'll check mesurements when I've got a sec.
Much appreciated.
Outside diameter of exhaust pipes is 70mm on tdi fr . Space between the two is 6.5mm, not much really, so think if you put chrome ones on they might be too close together
