Jul 5, 2025
Hi all!
I've been looking for a cupra 300 for a while now - I'm getting close to buying and wanted some advice.
I'm after a cupra 300 pre-gpf as I've heard post-gpf versions aren't as fun.
Is there an easy way to tell a pre-gpf car from a post-gpf car? Like something some search I can make or tell-take sign?
I know they were introduced roughly in mid 2018 but can't conclusively tell from postings.
Also if you have any advice on what else to look out for that would be much appreciated...I'm a noobie
Thanks!
I don't know if it's any different in the UK but in Europe, GPF equipped engine codes are DNUC for the hatchback and DNUE for the ST version.
Also, pre GPF cars have port injection (check under the hood) and usually a 6 speed DSG vs 7 speed for the GPF ones.
That's what I can think off the top of my head but better wait for a British member to confirm the above.
Thanks for the info! Do you know a way to get the engine code without an OBD port scanner thing? I doubt I'll be able to check the car using its port during the test drive.
You're welcome!
You can find it on the vin plate that's on the driver's or front passenger's side door, it's on a sticker along with other info, weight etc. Maybe also on the vehicle registration/permit or what you call it in your country.
