Cigarette Lighter
matt2e1cpc
Hi All,
Hopefully a quick question :)
I don't often use my cigarette lighter but had to use it today, it doesn't seem to stay in when pressed but does heat up if you press and hold it?
Are they meant to stay in and pop out when hot? This is on a Pre-FL Mk2 if that makes any difference.
Thanks,
Matt.
Bedlam
868
236
North Yorkshire
Had this problem with mine, I think using a device charger bends the internal "clamps",
use a non metallic item to narrow the diameter or metallic item (screwdriver) with IGNITION off.
In the end it was changed under warranty though...........
matt2e1cpc
Thanks Bedlam, that would make sense since I have a iPod charger left in pretty much permanently.
I'll have a look at bending the clamps back out.
Thanks,
Matt.
Bedlam
868
236
North Yorkshire
Back IN :)
Just remove ignition key to make sure it is not live..........i did not do this once, blew a fuse and went into limp mode !!!!
matt2e1cpc
Lol yes I guess it is in really isn't it :)
Will do my best not to blow myself up lol
SWANSWAY CUPRA Dealership
