Climate Control High Pressure Switch
sixarm
77
The climate control in my LCR isn't working at the moment, so I thought I'd run some diagnostics on it using this document. Using Code 1 - System Malfunction - the result is 22.1, which means "A/C Refrigerant High Pressure Switch, static open".
How do I go about resolving this issue?
With the weather so hot at the moment, I really want to get it sorted.
sixarm
77
have you recently had any work done on your air con? you could get the air con regassed that might help?
Nope, not had any work done on it. The annoying thing is I don't know when it actually stopped working as I've not really needed to use it until recently with all this sun we've had.
Black interior + sun = hot hot hot!
