asohotra
34
Just wondering want to upgrade the climate control unit on my 2007 SEAT Altea. Saw a video on YouTube (Golf 6 Climatronic 5K0 907 044 im Seat Leon 1p Vorfacelift) a bloke who had used the CC unit from a Golf 6 has anyone else done this previously?
Did you have any luck in the end?
Im currently looking to do a similar mod but using the facelift leon unit instead
I also used a facelift unit from a Leon and it works fine. Type 'Climate Control prelift to facelift unit' on search and that should help you. Let me know how you get on.
Awesome!
Do you have any pictures? Would love to see how it turned out
Sorry I can't seem to upload any pictures. If you can send me your email address I can send the pictures to you that way.
Hi i was wondering about facelifting options in my 2004 Altea until i found this thread and it really answered my questions about possibility to do so. But i have questions about climate control unit it self:
1) I see some of you used from facelift seat leon, but what about using from altea insteed?
2) I see there is difference in vents open/closing rotating knob does it work properly after upgrade?
3) Does vcds see the new climate control unit? Or does it need any coding?
Thanks for your replys in advance
P.S. sorry for my english.
P.S.S. i cant post picture to show what i have in mind:(
Firstly, your car must have climate control for the upgrade to work if I it doesn't then it won't work. If your car does have climate control then I think the upgrade Altea unit should work.
Yeah the climate control module itself goes to variuos cars and that is ok, what about plastic piece with vents?
I have figured out that 5P0907044S is the newer climate control module with heated seats and 5P0907044P is with out the heated seats, both these models were found in altea/leon/toledo.
And what about vcds coding?
I have not bothered with the coding as the unit works just fine. The plastic piece with the vents is different the part number is 5P2819110.
I upgraded the climate control unit on my 2007 SEAT Altea some time ago but now want to code the unit to my car as these are the only fault codes that come up on my car. Any ideas on how I can do this using VCDS?
Address 08: Auto HVAC Labels: 5K0-907-044.clb
Control Module Part Number: 5P0 907 044 P HW: 5P0 907 044 P
Component and/or Version: Climatronic H15 0702
Software Coding: 0000000003
Work Shop Code: WSC 99999 1023 2097151
ASAM Dataset: EV_Climatronic A01006 (SE35)
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3D2431E18DF1FC0224D-8068
2 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Motorsteuergerät - kein Signal/Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 215
Mileage: 253077 km
Date: 2000.00.00
Time: 10:23:30
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 215
Mileage: 253077 km
Date: 2000.00.00
Time: 10:23:30
