RobDon
Pro Detailer
Anyone had this? Car is '07 Leon 2.0 TDi DSG Stylance. When pulling away I get 2 clunks from the front end in quick succession, if you let off the gas quickly it clunks again? It also clunks when going over rough ground too.
I had it looked at and Autohaus said it was the offside shock and/or top bearing, these were replaced but it's still doing it. Going back in on Friday.
Any idea?
Maybe movement in the engine/gearbox mounts?
Also there is a common clunk from the subframe but that's usually only when going round corners
That thread is about a noise from the rear. Front strut and top bearing/mount have already been replaced and it's still doing it. They reckon the clunk may be the dual mass flywheel when you apply power to it on takeoff it clunks. Looking at just under £800 to supply and fit a new one. :(
sounds like an expensive maybe. any play in the driveshafts / CV joints?
Im going to say exhaust as I had this issue and when I had the dpf sorted it stopped doing it , i'd forgot about the noise till the missus mentioned it and realised it had stopped doing it .
Think I may have the same problem - clunks seem most noticeable when pulling away from stationary, usually when I take foot off throttle/ press the clutch. :(
How many miles has your car done robdon? My 57 has covered 64k so seems early for a flywheel failure, if that's my problem...
Think I'll be waiting for payday and keeping my fingers crossed for a less expensive fault!
This car has cost me £2k in the last 6 months - so do I get rid of it for something else or hang onto it now all of the big stuff has all been replaced (new turbo and flywheel)?
I know your dilemma very well. Sometimes it's a case of "better the devil you know than the one you don't". Could be anything next due to age and mileage, shocks, clutch, engine component, radiator. Those are just some of the issues that I've had with cars that never even had that many miles on the clock. My current car was 1 year old with 19k miles when I bought it and never had any issues few years until the ABS pump died. Shortly after that the rear door lock module was faulty. Cost of both was around £800. I decided to keep the car anyway and so far I've had no more issues. It's a gamble. :)
