clutch adjustment
Jugo23
61
Sheffield, UK
Hi all, i collected my cordoba today but biting point is on the floor, not in the middle. How do i adjust it to make biting point in the middle?
Seatmann
Rough around the edges
Sep 16, 2010
5,541
10
Scotlanda
If it's adjustable I think there should be an adjuster on the cable at the gearbox end, you might have a hydrolic one though in which case you can't adjust it. If you look where the brake master cylinder is and see if there's a small pipe coming from the resevior to feed the clutch.
JacketJ
105
Hampshire
Yeah, it is auto adjusting. Sounds like it could be the petal box, good luck.
You can check by looking through the open driver glovebox and pushing the pedal. Will probably need a torch to see.
Jugo23
61
Sheffield, UK
I checked the pedal box and it seems to have already been replaced, but there is some flex in the box. How do I strengthen the box without taking it off? The pedal itself is creaking and sticking aswel :-(
