Help me please.
I have just finished working on my Ibiza 1.2 2003.
I changed out the driveshaft.
To get to it from above I pulled out the line going to the slave cylinder and it leaked a bit
Sorted that out but the clutch pedal has zero resistance. The moment I push it it goes to the floor and doesn't come back until I grab it and pull it back. The gears won't change when the car is on. Only reverse gear will engage.
Brake fluid is under the minimum but still plenty visible in the reservoir so I doubt that is the issue but correct me if I'm wrong.
Also while changing out the driveshaft I put it in reverse gear so that it wouldn't keep turning and accodentally started the car while still in reverse so maybe that messed up something?
Any ideas.
Any ideas.
