Connor H
1,043
519
Essex
Clutch has started to slip as expected now at stage 2.
What are my options for clutch upgrades... do i have to replace everything or is there more cost effective route? Is a matter of just replacing the standard one or is an upgrade needed?
Also what are the cheaper brands like CG motorsport or drivetorque like, or stick with Sachs?
cheers
been directed to one of these friction plates to use with standard dmf set up...
What else would i need with this? I guess a new flywheel while its out...
Do i need a new cover plate too? I have a spare slave cylinder that got send with my replacement clutch pedal, its not new but will it work as a spare?
Wont a decent standard LUK clutch do?
Is the one in the car quite new and the stage 2 making it slip or is it an old clutch anyway?
I believe standard clutch is rated to 300lbft max and im over that
its an old clutch but its right as rain except now under heavy load i can tell its slipping, like i say it was to be expected to now im learning about clutches lol
Trying to spend as little as possible without cheaping out, debating what else to get with the uprated friction plate. Wish i could see the state of my flywheel without taking it all apart
Dazzalcr put a vid up on the what have you done to your car today thread the other day.
Im sure he talks about what clutch he used on that at the beginning.
Race centre plate with standard cover if memory serves.
Take a looksee. May give a bit of info you need ?
nice one bro ill check it out. thx for the replies
Reactions: Rich.T
Yeah hes got the one linked, looks like ill be getting that and probably a new flywheel soon
Reactions: Rich.T
Have you considered buying a full set - including flywheel - and just swapping out the uprated clutch plate? It's something I'm considering.
Reason being that it sounds like a flywheel on its own is stupid money when you can get one in a set for much less. The Sachs kit in looking at is around £300 - including the flywheel. I'm leaning closer and closer to getting a tune, so am just thinking I'll sell the clutch plate and buy an uprated one.
Of course, if you can't actually do that, that puts an end to that idea, but I can't see why not.
Not a bad idea at all actually, flywheel on its own seems to be around 300
Nice! ?
Thats pretty torquey lol.
Have you got an FR?
Is there any difference between the clutch on an FR and cupra r?
If not, i would have thought a standard clutch kit would do (with the R being 225 hp).
If they are different. Would a clutch kit n flywheel from an R fit?
Nice! ?
Have you got an FR?
yeah FR/cupra , its pretty torquey but it peaks early and then hp takes over
I dont think theres any difference in the models regards to clutch, just depends what model gearbox you have. I think theres 6 speed 02j and 02m and 5 speeds i have no clue lol
seems you can run the plate i linked above with the OEM cover and flywheel no issue.
Now im just deciding what the cheapest route will be, shouldnt have spent my money on handling mods haha
No idea whether my flywheel needs changing
Reactions: Rich.T
I would replace the flywheel. Peace of mind and all that.
Mine had a new standard clutch and flywheel about 6 months ago.
Im wondering how long that'll last now when i go stage 2.
Saying that, i never really push my car. For me its more an exercise in spending money i havnt really got lol
Reactions: oggydoodaa
You won’t have a problem at all. I use standard kit and have no issues what so ever, 283 brake and approx 295 lbs.
if you want more. Badger5 do an updates Sachs 4 paddle clutch plate which you use with the rest of oem parts. Good foe 400 brake apparently.
I had one but never fitted due to **** up with mechanic.
Had my standard set up for over 3 years with lots of track time snd have. O issues.
Badger5 Custom Map + TIP,
Reactions: Rich.T
02m is 6 speed
02j is 5 speed
Thank you for correcting me!
Suppose i might as well get a new flywheel. Is it worth getting a new cover too or just the paddle plate?
My daily driving as all good, its just when i slap the pedal to the floor its all noise no go haha
If it were me I’d change it all for oem clutch Kit
I’m no mechanic but If I’m having the work done if it’s open I change it so it’s done once. Flywheel dependant on inspection though.
Think im gonna find the best priced standard Luk kit and switch out the clutch plate for sachs ,hmmm
