gard_ian8
174
I've had my Supercopa less than a week and the low suspension is doing my head in! I was told by the garage that it had coilovers fitted and they were adjustable.I got the tools form the garage to do it.
I have been to see my mate tonight and he put the car on the ramp and then told me that the back suspension isn't adjustable as the shocker and the spring are separate and cannot be adjusted. I am confused as I thought coilovers were adjustable?
I am now looking to get the suspension sorted. Would I need to buy some new rear springs and shocks to raise the rear up? I am hoping i can keep the front (which is adjustable) and then match the height of the rear, would this work?
This is abit of a yes and no answer from me with the adjustable front coilovers you can mach the height but it depends if they are fully adjustable as your rebound and damping will be way off unless they have there own adjusters on them.
Can you take a picture of them and me/someone else might be able to identify them and see how adjustable they really are :D
I can see if I can get the car in the air tomorrow. Reading a lot on here since I got back in and I have read "The suspension at the rear just has a spring sitting on top of an adjustable sleeve. I have to remove the springs and take the adjusters out, to lower or raise" so could it be that the rear springs are adjustable? So the sprigs could be adjustable after all? I'm no mechanic so some advice would be great.
