MarkBournemouth
Model: Toledo 20V SE, year 2000.
This site is my last resort. I don't want to, but I'm coming to the stage where I'm thinking of getting shot of this thing completely and getting myself something Japanese! The car's got a problem that's even got a VAG specialist stumped. As follows.....
A year or so ago, it developed a problem where it would start hesitating under load. Garage pinpointed it to a failed O2 sensor. That was replaced, and the car was fine. Then about six weeks ago same problems/symptoms again- hesitation, misfire, erratic idle etc.
Back to the garage, and they ran a diagnostic on it. Failure code came up, but apparently, this time it wasn't the O2 sensor. They cleaned the MAFF, plugs, checked the leads and all the other gubbins, and cleared the fault code. Car was fine until a couple of weeks ago, when it started again. Drove to work in the morning, all was perfect. Started it to come home, and the idle was uneven, misfiring and the hesitation/loss of power was back. Took it back to the garage; same failure code. They cleared it again. Started it the next morning and it's off again.
Funny thing is that once the engine's warmed, it seems to be fine, although I can tell it's definitely not right. It's never done this with a cold engine in the past though.
I reckon it's something ignition/engine management system related, as it's on startup that seems to make this problem kick in.
Has anyone else had this problem, or can you offer any advice/ideas?
