Cold start problems. Help!
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
Hi guys
I’m in need of some information please.
For a few months through summer my car has on most occasions fired up with a cold start. With the revs up high.
It’s done this even at midday in 20 degrees.
It only does it for the first fire up. Once it’s been run for a minute it won’t do it again.
It throws up no code faults.
I get that it’s a sensor which must be failing and not reading a proper temperature at initial start, but does anyone know exactly which sensor governs the cold start up activation?
Just changing out thermostats and temp senders Willy nilly would cost a packet.
Any help appreciated.
Badger5 Custom Map + TIP,
Alexis27
2,206
540
Manchester
Do you get the EPC light showing?
Warm start problems are often the crankshaft sensor. But it often throws a code
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
No. No codes. No lights.
Seems whatever isn’t reading correctly hasn’t actually failed completely.
Just a guess.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
No errors.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
The only sensor that affects the mixture at start up is the coolant one. Can't see it can really be much else other than that.
Result as have ordered one. Thnx.
Reactions: mty12345
