Coming home lights question
shifimofo
I haven't found anything via the search but I apologise if I missed something.
This evening I left my lights on whilst I went into the house and proceeded to lock the car doors (just in case) and to my surprise when I returned to the car all the lights had switched off! I unlocked, opened the door, put the key in and then the lights came back on. They were left in the fully on position.
I've had the car less than a week, but I was under the impression that you needed the auto lights feature for this to work, which my car doesn't have. If I can use this without worrying about the battery in the morning then that would be great as the parking at the rear of my house is unlit, so would make things a little easier!
Thanks in advance for any help you can give!
Car in question is a 56 Leon FR.
/dev/null
1,652
101
No, it's standard across the Leon range. The "auto" lights feature is different, that is where the lights come on automatically based upon how dark it is (ie a sensor). Coming home lights are just on a timer. It can be enabled and disabled using VCDS.
shifimofo
Legend. Couldn't have asked for a more simple explanation!
/dev/null
1,652
101
Not a problem. Remember though that it only works on dipped beam - if you leave just your sidelights on then they will stay on. Or if you put your indicator on then whichever side will stay lit (parking light).
dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
I think with a bit of VCDS magic, you can turn on leaving home lights but without the rain/light sensors, they'll only work if you leave you main beam on in the same way as the scenario as above. Could be wrong though?
Gazza_24
363
Tried that on mine but it didn't work, I have the come home feature but not leave home feature :(
Top Dog
220
Wolverhampton
I have done this ever since i have had my 08 K1, also the previous owner told me he leaves them on also. I like the feature but would like them to come on when i unlock the car. Is that possible through VCDS?
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
As said, VCDS is your friend for doing this. There is a thread all about it in the MK2 section with ebay links for buying a fake cable and downloading the software. Should cost about £25-30, then you can enable loads of stuff like the leaving home lights, remote windows, hazard flash with ABS activation, Alarm arm and disarm bleep and loads more. Also you can read and reset faults as well as diagnosing problems and running logs.
Or you could pay hundreds for the registered VCDS or hundreds to the stealers for fixing easy faults.
Gazza_24
363
Already have all those features activated :p
matt l
391
stupid question... how i have the coming home lights activated on a 10second thing, however if i leave my lights on all it does when i take the keys out is put them on to side lights, doesnt turn them off.
what am i doing wrong?
Redemption
1,771
Hampshire
I have to flash my main beam once to activate mine. Maybe yours is the same.
/dev/null
1,652
101
Post a request in the vag-com help section on here, stating where you are etc. Someone may live near you who is willing to meet up and sort it if needed.
jordanogrady
290
I'm also struggling to understand this, i have a 2010 leon, auto lights and xenons. i've set my coming home and leaving home to 30s. but not sure what this does?
I've left my lights on auto, and as soon as i take my key out, all the lights go off.... i thought dip beam was supposed to stay on?
also, whats leaving one do?
Jordan
